AutoCAD Forum
Help with lisp to Automatically break multiple lines/poly lines
3 REPLIES 3
bgraverholt
777 Views, 3 Replies
I am looking for some help on making a lisp to break multiple intersecting lines that I select vertically and if it is posible if the breaks overlap to break the line horizontaly instead. Hopefully somone has a solution.
3 REPLIES 3
in reply to: bgraverholt
I do a lot of electrical drawings and I draw lines that intersect each other then come back later and "break" those intersections. I put a arc at the intersections and break the vertical lines. I edited acad2015.lsp (using wordpad) and added the following:
(defun C:JMP ()
     (setq pt(getpoint "nPT: "))
     (COMMAND "ARC" "C" pt "@0,-.0625" "@0,.0625")
     (COMMAND "TRIM" "LAST" "" "CROSSING" "@.03125,-.0468" "@-.03125,.03125" "")
I would imagine that you could change this to get what you want (and make two of them . . . one for vertical & one for horizontal.
To run the one that I created I open the drawing with AutoCAD and type JMP at the command prompt. AutoCAD will prompt for the intersection of the lines, I select an intersection and the arc is drawn and the line between the arc is trimmed out. note that I need to be zoomed in fairly close for this to work properly for some reason.
bgraverholt
That would work but the only problem is I wouldn't want the arc. Not sure how I would accomplish that.
HullDrafter
I would suggest moving your request over to the customization folder, the LISP programmers there will be able to answer your question.
”Boost
