I've created a 3D model using Autodesk Inventor. Now I need to make a 3rd angle projection of this model. Since I'm fairly new to AutoCad, I'm wondering if you could supply me with some information/tutorials. As of now, I've already understood the basics of AC and can create singe projections of my 3D model. Be that as it may, I'm still unable to create a full 3rd angle projection using AC with exact dimensions and labels.
I would greatly appreciate your help,
Max
Is there a reason you are not doing this drawing in Inventor?
Can you save the model as an AutoCAD dwg and use the viewbase command in AutoCAD?
Or can you use the viewbase command on the Inventor model in AutoCAD?
Can you attach the file here?
