AutoCAD 2013/2014/2015
Member
BENDTECH
Message 1 of 7 (210 Views)
HATCH
210 Views, 6 Replies
07-22-2012 10:01 PM
 I AM TRYING TO PATTERN A SKETCH, BY USING HATCH PATTERN. HOW TO ADD A SKETCH IN TO THE HATCH LIBRARY?
Bob_Zurunkle
Message 2 of 7 (192 Views)
Re: HATCH
07-23-2012 09:31 AM in reply to: BENDTECH
Ummm I think you'll need to elaborate a bit...
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted :smileyhappy:
Active Member
a3dtot
Message 3 of 7 (160 Views)
Re: HATCH
07-26-2012 02:28 PM in reply to: BENDTECH
If you are trying to create a hatch pattern based on your sketch I believe there are more steps involved.
I can't help you with creating hatch patterns haven't done any in about 20 years but you can post again to clarify
what you are wanting to do and others will be able to help you.
mathewk
Message 4 of 7 (153 Views)
Re: HATCH
07-26-2012 06:18 PM in reply to: BENDTECH
Try the express tool superhatch.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
Member
BENDTECH
Message 5 of 7 (151 Views)
Re: HATCH
07-26-2012 06:46 PM in reply to: BENDTECH
Can anyone please elaborate how to use the superhatch function.
Member
BENDTECH
Message 6 of 7 (150 Views)
Re: HATCH
07-26-2012 06:49 PM in reply to: Bob_Zurunkle
Hello , Can you please elaborate how to use the superhatch function. Best Regards Krishnan
grimline
Message 7 of 7 (144 Views)
Re: HATCH
07-26-2012 09:18 PM in reply to: BENDTECH
Create a block with just lines or imported images. Then, command SUPERHATCH. Select the block you just created.
Autodesk AutoCAD Map 3D 2015
Windows 7 Professional
Service Pack 1
Intel(R) Core(TM) i5-4430 CPU @ 3.00 GHz
8.00 GB RAM
You are not logged in.
    Come hangout with Autodesk Support Specialist and AutoCAD guru Volker Cocco, to learn about Precision Drafting: Object Snaps and Object Tracking on July 31 @ 11:00 AM PST.
    Click here for registration information!
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
