AutoCAD 2013/2014/2015
New Member
j-m.fontaine
Message 1 of 2 (93 Views)
Grid array function bugs
93 Views, 1 Replies
01-14-2013 12:50 AM
Creating a grid array with solid fills inside (not test others) seems to refer to itself, and the file cannot be opened.
The application does respond to Windows and memory used by ACAD.exe increases and increases...
Find attached the file.
*Expert Elite*
drjohn
Message 2 of 2 (83 Views)
Re: Grid array function bugs
01-14-2013 08:08 AM in reply to: j-m.fontaine
If it is refering to itself, you may have a block in the drawing with the same name as the filename.  Rename the file and see if that helps. Worked for me.
On a side note, RECOVER the drawing rather than OPEN cause there is an error in it that will be corrected with RECOVER.
DJ
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
