AutoCAD Forum
Graphics glitch in layout tabs
4 REPLIES 4
flutterbird42
637 Views, 4 Replies
I am having trouble with the graphics in my layouts tabs. When I select the layout tab, I cannot move the drawing with my right mouse button, nor can I select the viewport. The wierdest thing is that when I move my mouse (without clicking or giving any commands) the image changes. I have attached some screenshots so you can see what I'm trying to describe. This problem started suddenly, and occurs on new, old, and blank drawing files.
4 REPLIES 4
hello sir,
 I think your problem is your hardware, try to check/update or uprade you memory card and video card.. its either low memory or low resolution or maybe its not updated or compatible...
hope this will help..
regards
Virgilio Benedictos
Virgilio Benedictos
AutoCAD 2011 Certified Associate
Please give Kudo if problem solve.
JoAnn_Hogan
in reply to: flutterbird42
Hi There,
First of all Welcome to the community.
Just a few questions: Do you have all the latest service packs installed for your AutoCAD? Do you have the lastest Graphics drivers installed?
If this post solved your issue please mark as solved and Kudos are always welcome 😃
Jo - Ann
Twitter: @JoAnn_Hogan
Revit Architecture Certified Professional / Revit Structure Certified Professional / AutoCAD Certified Professional
braudpat
Hello
A few questions :
Q1) Which version of AutoCAD ?
Q2) 32 or 64 bits ?
Q3) Which Windows exactly ?
Q4) Which graphic card ?
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Updating my video card drivers seemed to do the trick.
Thanks!
”Boost
