Flipping the direction of the constrain dimension,
I couldn’t figure out how to flip the direction of the constrain dimension (attached) while working in the block editor environment.
Thank you
Best
Jamal
Solved by dmfrazier. Go to Solution.
Many thanks dmfrazier for the help. Creation of the dimension the opposite way does work Just I wanted to know if there is a tool to flip the direction. Best Jamal
No special "tool" that I'm aware of.
I think you can also just drag the grips back and forth to reverse the order/direction.
Many thanks dmfrazier.
A colleague advised that the “reverse” command might do the job
