I have an imported 3D model with hundreds of solids. The problem is that all solids are in the same layer.
Is there any option to filter them (as a prelimanary step to sort them) by their volume, as there a lot of them that are the same (such as bolts, small plates and so on)?
Thank you very much
Jorge
Thank you very much
Jorge
Kind of brute-force, and without the usual enhancements, but this seems to work, in limited testing:
;; SortSolidsBySize.lsp ; [command name: SSBS]
;; To create a list of selected 3D Solids, pairing their entity names with
;; their volumes, and sorted by volume from smallest to largest.
;; Kent Cooper, 13 May 2014
(defun C:SSBS (/ ss sol propfile propline)
(setq ss (ssget '((0 . "3DSOLID"))))
(repeat (setq inc (sslength ss))
(setq sol (ssname ss (setq inc (1- inc))))
(command "_.massprop" sol "" "_yes" "C:/SSBStemp.mpr")
(setq
propfile (open "C:/SSBStemp.mpr" "r")
propline (read-line propfile)
); setq
(while (/= (substr propline 1 1) "V") (setq propline (read-line propfile))); find the Volume line
(setq solidlist
(cons
(list sol (atof (vl-string-left-trim "Volume: " propline))); take the heading off, convert to number
solidlist
); cons
); setq
(close propfile)
(vl-file-delete "C:/SSBStemp.mpr")
); repeat
(setq sortedlist (vl-sort solidlist '(lambda (x y) (< (cadr x) (cadr y))))); use > instead to sort largest-to-smallest
); defun
It leaves you both the sortedlist variable in size order and the [unsorted] solidlist variable, but you can localize the latter so it won't stick around, if you have no use for it.
If there's a way I couldn't find to extract the results of MASSPROP from a System Variable or something, rather than going through a text file, that could streamline the whole thing.
Volume of 3dSolid entities is available as a vla-property. It doesn't show up in the Properties palette, so it can't be used with a conventional selection method.
@dgorsman wrote:
Volume of 3dSolid entities is available as a vla-property. ....
So it is! I was looking only at the MASSPROP command approach, because it was the only thing I was aware of that got at the volume, but apparently not.... That makes it a lot simpler -- no external file, etc.:
;; Kent Cooper, 13 May 2014 [with simplification help from dgorsman]
(setq
solidlist
(cons
(list sol (vla-get-Volume (vlax-ename->vla-object sol)))
solidlist
); cons & solidlist
); setq
); repeat
); defun
