Hey guys,
still pretty new to AutoCAD, having a problem filleting the edge of a cylinder.
For some reason, I've tried to fillet both sides of the shape but an error occurs... No matter what radius i add, I cannot round both sides at once. The only thing that has succeeded is by rounding only one side of the shape, however when i try to round the other side, another error occurs.
I've attached a screeshot to help explain...
Any idea what this may be?
-David
If you are talking about the platter shape it looks like the radius on top does not leave enough material to fillet the bottom. In this case I would draw a 2D polyline of a section cut of half the platter shape with the rounded end already on it then revolve it.
@davidroyer wrote:
.... No matter what radius i add,....
-David
Can you attach your *.dwg file here?
Thanks JD,
Here it is! I would really appreciate the help, i cant figure what to do.
-David
@davidroyer wrote:Thanks JD,
-David
Works here.
Fillet using half the thickness of the platter as the radius worked fine for me in AutoCAD 2013.
