Hi Guys,
I got a serious problem, to which I have so far not found a solution.
I partner with a team of other consultant and have to expect files from different CAD versions (I guess).
The situation is;
There is nothing to purge, nothing to delete, nothing to audit etc.
As we are working with a team of international consultants, we don't want to "Copy & Paste" as we may loose some data which may be needed later on.
Do any of you have any solution to this.
Lastly, in advance, Thanks a lot guys,
Cheers
Sounds like it could be the DGN bloat issue.
I don't see any AutoCad version listed but have you installed and tried the AutoCad DGN Hotfix ?
The Hotfix is needed if using 2014 or older but AutoCAD 2015 products, including AutoCAD LT,
now have an additional checkbox item in the PURGE dialog which will remove the unused DGN
linetype information from drawings.
have you tried to load the drawing with your 2013 release and let the DGN Hotfix run over your drawing?
- alfred -
