The company i work for has upgraded to AC2014 on 3 machines. The remaining stations with autocad are running AC2008 (occasional users).
I have found or at least I believe it is the cause, when a new drawing is created with 2014 and saved back for 2008 to open and then that file is opened with 2008 and saved. This will cause an error message reporting hundreds/thousands of errors when reopened in 2014. A recovery finds/fixes 0 errors. I can't get rid of the error report, unless I copy and paste the contents into a fresh template an resave. Opening more than 1 of these drawings will cause a fatal error. I have the SP for 2014.
The drawings have no issues when opened with 2008.
Has anyone a similar experience? If so, any fix?
regards
Sean
Hello Dean,
Thank you for your reply. Yes, our machines "savefidelity" are set to 1. I'll test turning this off.
I haven't tried the export option. I'll test this today and let you know how it goes.
Thanks again
Regards
Sean
Dean,
No luck so far, although turning off the "savefidelity" in 2008 and saving caused AC2014 to actually find/fix errors when recovered (not all errors though). I'm still copying/pasting to new template to work around it.
Regards
Sean
