I am using AutoCAD 2013. Past one week i am geting this Fatal Error message. When i give any command its close with fatal error. I check with .Net Framework, ans i cleane with cccleaner, but still i have th same issue. Then i uninstall AutoCAD then re install AutoCAD it work, but when i close & reopen the application. i cam retain the same issue.
I attached print screen.
Karthikeyan.
