Hi; i have a problem when i try to modify materials on Autocad 2014, i get the following error: "FATAL ERROR: Unhandled Access Violation reading 0x0050 Exception at ce24fa48h" somebody can help me? thanks
I am still trying to find the information you are looking for, and someone may beat me to the answer, but I have just a couple extra questions. 1) is this one of your drawings?
2) If not, what AutoCAD version or rather variation was used to create this? (It looks like something a friend used to do with Revit). I can't remember the last time I had an error like this. But, I'll keep looking.
HD
>> but it appen with, autocad 2014, autocad 2015, and i also tried to reinstall both the programs
Well for AutoCAD 2014 I would have verified first the service pack, is this up-to-date? And if you do a reinstall ... have you reinstalled the material libraries too?
For AutoCAD 2015 ... did you migrate the settings when you first started 2015, so it imported something from your 2014-settings? If so, it might also be the profile that has defects. You can use the "resetting to defaults" option (in the Windows start menu ==> Autodesk section) to make the AutoCAD profile clean (if you have done any customizations then please back them up before resetting).
HTH, - alfred -
