Dear All,
I usually got the FATAL ERROR when i run eTransmit for the first time. Then I open ACAD again and run eTransmit, it runs weel.
I tested this 3 times today with 3 seperate machines.
Do you have any ideas. Sheet Set or eTransmit may cause this problem?
Thanks.
You can try to make a new transmittal setup.
Hit the button "Transmittal Setups..."
Now you can make en new one or modify an existing.
A transmittal setup is saved in the windows registry! So you have to do it for each PC
I did a transmittal set up. Other PCs just use that. The problem occurs when they right click on drawings from Sheet Set then choose eTransmit.
