AutoCAD Forum
FATAL ERROR: out of memory, when openning Specific Drawing
10 REPLIES 10
Message 1 of 11
alx86
2915 Views, 10 Replies
I have a weird problem which I'm not sure if it's a AutoCAD problem or a network issue. We are 7 drafters and our drawings are saved on a Network. We have some drawings that at some point kind of get corrupted and won't open on any of the 7 computers. Any other drawing will open fine with no error, but when we try to open the "corrupted" drawing we instantly get the (FATAL ERROR: Out of memory) message and can't do nothing with it.
The drawings are really simple and not a big file (228ko and 473ko)
It's the 2nd time this happen withing 3 days on 2 different .dwg. The first time, we were able to open the drawing but can't do anything in it. Even draw a simple line was resulting in AutoCAD to give the message. The .bak was also unusable but I've been able to insert the corrupted drawing as an XREF in a new DWG, bind it and explode it, but the 2nd time I wasn't able to insert it as a XREF but we were lucky enough that the .BAK was up to date and not corrupted.
I've attached the drawing with this post.
10 REPLIES 10
Message 2 of 11
Jay_B
in reply to: alx86
The file won't open for me using either the normal OPEN using the RECOVER drawing utility.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 3 of 11
sthompson1021
in reply to: alx86
Hi, I was able to open the drawing with no problem. I ran an audit on it and it came back with no errors.
Message 4 of 11
in reply to: Jay_B
Opens fine for me. Audit detects no errors.
Message 5 of 11
alx86
That's strange. You've been able to open it and it gave you no error? Since I can't open the file, I can't run an Audit on it, but I've tried to run a recover on the drawing, but it gave me the same Fatal Error.
Message 6 of 11
alx86
in reply to: alx86
Here's a link to a screencap I've made to show what it does when I try to recover.
http://www.youtube.com/watch?v=NA67qGS1HW8&feature=youtu.be
Message 7 of 11
sthompson1021
in reply to: alx86
Are you able to open the dwg that Laser Guy posted?
Message 8 of 11
alx86
in reply to: sthompson1021
Yes, both of them, but I can't ask Laser Guy to correct them for me all the time 😉
Message 9 of 11
sthompson1021
in reply to: alx86
Do you use any add on's or run any custom lisp routines?
Message 10 of 11
alx86
We have no add-on installed, but I've made a Lisp file regrouping some Lisp in it and some Key Shortcut I've created for myself. But I've been using this lisp for about 4 years on Acad 2007 and about a year in Acad 2013, so I don't think that lisp is the source of this.
I've attach my lisp with this post in case someone want to look at it.
Message 11 of 11
pendean
in reply to: alx86
Your error message may have nothing to do with the file in question: as a test when this happens again, place the file on a local PC (after you restart the PC), unplug from your network and try to open it.
Your file have no issues, I can open it in plain R2014 as noted above.
”Boost
