I'm trying to create a gear by drawing a circle and a single tooth for a gear, then using a polar array to create teeth around the circle. When I extrude this shape, it is not a solid, and I can hatch one face of it, but not the other. How do I convert this object to be a solid 3d object when extruded?
Try Presspull rather than Extrude.
you have an opening somewhere in your profile
attach your *.ipt file here and someone will find it for you and show you where it is at.
