Hi All,
On one computer, when we use ET>Text Mask, the result is that the mask hides the text. I can select the text/mask but they seem to be in the wrong draw order. I used the TextToFront command and this didn't fix it.
Any ideas what is wrong here?
TIA,
Sal
Solved by jggerth. Go to Solution.
start command _DRAWORDER one time manually, switch some test objects forward and backward and then let _REGEN run once ... better now?
I would also verify that in a new drawing.
For the existing drawing doing one time _AUDIT may also help for the consistency of the database of the drawing objects.
Good luck, - alfred -
You said 'one computer'. Does the same drawing display with the correct draworder on other machines? if that's the case, try doing a repair of the install on the troublesome pc from Control Panel.
Alternatively, why not use Mtext with background masking? that's my go-to choice for text masking...
