AutoCAD Forum
Exportlayout fails "eNotAllowedForThisProxy"
4 REPLIES 4
duncan.lithgow
2887 Views, 4 Replies
I'm trying to export some DWG from a lareg DWG to a smaller one to be linked in to Revit. But I can't get the EXPORTLAYOUT command to work. I get an unhandled error exception
I've tried savingto the server (remote hosted over VPN) and to my own Desktop, makes no difference.
Any ideas out there?
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
Autodesk.AutoCAD.Runtime.Exception: eNotAllowedForThisProxy
   at Autodesk.AutoCAD.ExportLayoutUI.Commands.ExportLayout()
   at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker(MethodInfo mi, Object commandObject, Boolean bLispFunction)
   at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorkerWithExceptionFilter(MethodInfo mi, Object commandObject, Boolean bLispFunction)
   at Autodesk.AutoCAD.Runtime.PerDocumentCommandClass.Invoke(MethodInfo mi, Boolean bLispFunction)
   at Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk.Invoke()
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.0.30319.34011 built by: FX45W81RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Acdbmgd
    Assembly Version: 19.1.0.0
    Win32 Version: 19.1.108.0.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/AcdbMgd.DLL
System
    Win32 Version: 4.0.30319.34003 built by: FX45W81RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
    Win32 Version: 4.0.30319.33440 built by: FX45W81RTMREL
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
AdApplicationFrame
    Assembly Version: 0.0.0.0
    Win32 Version: 4.0.19.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/AdApplicationFrame.DLL
AdWindows
    Assembly Version: 4.0.36.100
    Win32 Version: 4.0.36.100
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/AdWindows.DLL
PresentationFramework
    Win32 Version: 4.0.30319.34004
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
WindowsBase
    Win32 Version: 4.0.30319.34004 built by: FX45W81RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
PresentationCore
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
System.Xaml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
System.Xml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
PresentationFramework.Aero2
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero2/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero2.dll
System.Drawing
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
accoremgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/accoremgd.DLL
Acmgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/Acmgd.DLL
System.Configuration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
AcWindows
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/AcWindows.DLL
AcCui
    Win32 Version: 19.1.18.0.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/AcCui.DLL
PresentationFramework-SystemXml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
WindowsFormsIntegration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
AcWindows.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/en-US/AcWindows.resources.DLL
System.Windows.Forms
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
PresentationUI
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationUI/v4.0_4.0.0.0__31bf3856ad364e35/PresentationUI.dll
System.Xml.Linq
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
PresentationFramework-SystemXmlLinq
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXmlLinq/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXmlLinq.dll
UIAutomationTypes
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
ContextualTabSelectorRules
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/AcWindows.dll
PresentationFramework-SystemCore
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemCore/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemCore.dll
Microsoft.Expression.Interactions
    Win32 Version: 2.0.20520.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/Microsoft.Expression.Interactions.DLL
ManagedMC3
    Assembly Version: 7.2.0.0
    Win32 Version: 7.2.0.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/ManagedMC3.DLL
AcAeNet.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/en-US/AcAeNet.resources.DLL
AcButterflyExt.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/en-US/AcButterflyExt.resources.DLL
AcCloudRender.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/en-US/AcCloudRender.resources.DLL
AcCustomize.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/en-US/AcCustomize.resources.DLL
AcDxWizard.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/en-US/AcDxWizard.resources.DLL
AcExportLayoutUI.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/en-US/AcExportLayoutUI.resources.DLL
AcInterfere.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/en-US/AcInterfere.resources.DLL
AcLayer.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/en-US/AcLayer.resources.DLL
AcLayerTools.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/en-US/AcLayerTools.resources.DLL
AcMrUi.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/en-US/AcMrUi.resources.DLL
AcMultiLineUi.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/en-US/AcMultiLineUi.resources.DLL
AcRecoverAll.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/en-US/AcRecoverAll.resources.DLL
AcScaleList.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/en-US/AcScaleList.resources.DLL
AcUnderlay.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/en-US/AcUnderlay.resources.DLL
AcViewTransitionsUi.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/en-US/AcViewTransitionsUi.resources.DLL
AdskConnectionPointMgd.resources
    Assembly Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/en-US/AdskConnectionPointMgd.resources.DLL
AcCalcUi.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/en-US/AcCalcUi.resources.DLL
AcLayer
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/AcLayer.DLL
Accessibility
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
AcMr
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/AcMr.DLL
System.Runtime.Serialization
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
AcLivePreviewContext
UIAutomationProvider
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
PresentationFramework.Luna
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Luna/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Luna.dll
AcMrUi
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/AcMrUI.DLL
AcDialogToolTips
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/AcDialogToolTips.DLL
AcDialogToolTips.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/en-US/AcDialogToolTips.resources.DLL
AcExportLayoutUI
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/AcExportLayoutUI.DLL
AcExportLayout
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/AcExportLayout.DLL
AcExportLayoutEx
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/AcExportLayoutEx.DLL
AcTaskDialogs
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/AcTaskDialogs.DLL
AcTaskDialogs.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202014/en-US/AcTaskDialogs.resources.DLL
************** JIT Debugging **************
Application does not support Windows Forms just-in-time (JIT)
debugging. Contact the application author for more
information.
Tags (1)
4 REPLIES 4
dmfrazier
in reply to: duncan.lithgow
Does this happen with one (or just a few) DWG file(s) in particular, or with any (all) file(s) with which you use the command?
Assuming it's only one (or a few), and based on the existence of the word "proxy" in the error code, I'm going to guess that the error is related to a custom object (or objects) in the DWG for which you do not have the creating application, and possibly no "enabler" installed either.  For more info, see:
http://knowledge.autodesk.com/support/autocad/getting-started/caas/documentation/ACD/2014/ENU/files/...
Some things to check and try:
Do you have PROXYNOTICE turned "on" (=1)?
Do you have PROXYSHOW turned "on" (=1 or 2)?
Is PROXYGRAPHICS turned "on" (=1) in the DWG?
Do you have DEMANDLOAD turned "on" for objects and commands (=3)?
If you are able to determine that there are custom objects (or proxies) in the DWG(s), then it might help to download and install one or more object enablers.  If so, you might find what you need with this link:
http://knowledge.autodesk.com/support/autocad/downloads#?ADSKContentGroup-local=Downloads&ADSKProduc...
duncan.lithgow
in reply to: dmfrazier
Hi dmfrazier, thanks for your answer
You wrote about proxies, so while opening the file I chose not to show proxies. This made no difference.
So then I opened it again chosing to show proxy graphics to check through your list:
Yes, =1 - Do you have PROXYNOTICE turned "on" (=1)?
No, =0 - Do you have PROXYSHOW turned "on" (=1 or 2)?
No, =0 - Is PROXYGRAPHICS turned "on" (=1) in the DWG?
No, =0 - Do you have DEMANDLOAD turned "on" for objects and commands (=3)?
All those nos confuse me, I chose to have them shown.
I'm new to proxy graophics, but as I understand it I have two options. Or I can install an/some object enablers. But how do I know which ones I need?
I've also read that I can export the file to a new DWG losing all blocks and 'exploding' all proxy graphics. But DWG is not an option under Export. So I don't quite understand this option.
What I'm trying to do is have a Layout set up where I can export every now and then as the project progresses, to my Revit collegues. They complain that otherwise the file is to big (geometrically) and contains lots of distracting information (layers) not relevant to their purpose.
pendean
EXPORTTOLAYOUT destroys your 1:1 scale: is that what your REVIT users want to use?
I would think the better approach be to use WBLOCK command to extract only the geometry they need with only relevant layers instead.
dmfrazier
"I'm new to proxy graophics, but as I understand it I have two options. Or I can install an/some object enablers. But how do I know which ones I need?"
With ProxyNotice turned on, you should see (in the notice) which "applications" are missing (if any).  You can use this as a guide, but it might be simpler to just download and install all available Enablers for your version.
Bear in mind that my advice here is based on a "working hypothesis" (that the error is related to a custom object - or objects - in the DWG for which you do not have the creating application, and possibly no "enabler" installed either) which may very well be incorrect.  The only way to find out is by testing the hypothesis.  There are certainly other possible explanations.
"I've also read that I can export the file to a new DWG losing all blocks and 'exploding' all proxy graphics. But DWG is not an option under Export. So I don't quite understand this option."
Block (*.dwg) is an Export option (in my seat of AutoCAD 2013), but I think it is essentially the same thing as WBlock (mentioned elsewhere), but I'm not sure what else this might refer to.  Does the stuff you've read not specify the command or method to use?
”Boost
