AutoCAD 2013/2014/2015
Active Contributor
Message 1 of 9 (141 Views)
Export Model Space or Secure Layers
141 Views, 8 Replies
04-24-2013 06:53 AM
Is there a way within Autocad to lock a layer so that only certain people have access (say using a password).
Also is there a way to export model space from one workbook to another. In that one is the standard company file and I want to build a sepearte workbook for my purposes (making specific paper spaces etc...) but I want to use their model space for the model space of my workbook. Also if possible to export would this exported model space make changes when changes were made on the original copy?
*Expert Elite*
Patchy
Message 2 of 9 (128 Views)
Re: Export Model Space or Secure Layers
04-24-2013 07:14 AM in reply to: JaredMcCullough
Nothing comes with autocad that can lock a layer with password.
What is workbook?
Active Contributor
Message 3 of 9 (117 Views)
04-24-2013 07:29 AM in reply to: Patchy
Sorry I was referencing files. Say at my company the engineering dept has a file with just a basic drawing in model space. I want to use the same model space in my file but be able to create layers and paper sources specific to the work I am doing. This being said I need it to update (revise) when the make changes in their file.
Example: They have a circle in model space. I want my model space to be the same circle but if they put a square inside their circle I need mine to update with that.
Essentially some sort of exporting or translating model space to different files.
*Expert Elite*
Patchy
Message 4 of 9 (113 Views)
04-24-2013 07:32 AM in reply to: JaredMcCullough
How about using XREF.
Active Contributor
Message 5 of 9 (109 Views)
04-24-2013 07:36 AM in reply to: Patchy
thank you for the quick reply patchy.
First Question: Will this update as they update their files?
Second Question: Can you provide me with where I can find more insight on XREF
*Expert Elite*
Patchy
Message 6 of 9 (99 Views)
04-24-2013 07:42 AM in reply to: JaredMcCullough
Use XREF command, use Overlay, and load their drawing(s) into your drawing.
When autocad detects their update it will tell you the Xref drawing had been modified.
Youtube.com should have many about how to use XREF drawings.
*Expert Elite*
dgorsman
Message 7 of 9 (92 Views)
04-24-2013 07:44 AM in reply to: JaredMcCullough
External references are one of the core concepts in AutoCAD.  I cant' recommend strongly enough that you get familiar with them.
If you are going to fly by the seat of your pants, expect friction burns.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
Active Contributor
Message 8 of 9 (92 Views)
04-24-2013 07:46 AM in reply to: Patchy
Patchy I apologize but two more questions:
First you say that it notifies you of the changes but do you actually have to physcially make the changes yourself or does it apply them and just notify you to let you know
Second these can you make any changes to the layers of these drawing(s) in your document or does it act as one single layer when XREF is used
Active Contributor
Message 9 of 9 (88 Views)
04-24-2013 07:48 AM in reply to: dgorsman
Thank you dgorsman I first wanted to make sure it was the most applicable way to approach my intended goal and now I plan on doing some homework hurray!!!
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
