AutoCAD 2013/2014/2015
Member
Message 1 of 6 (441 Views)
Excel OLE qualty when ploted to PDF
441 Views, 5 Replies
01-04-2013 08:04 AM
I have been trying to figure this out for an about a day now. I just downloaded the AutoCAD 2013 Free Trail (Company is considering upgrading from AutoCAD MEP 2009). I have been trying to plot to PDF using the Adobe PDF plotter option which has worked perfectly on AutoCAD MEP 2009. When I plot to Adobe PDF using 2013 the Excel 2007 OLE that I copy and paste into AutoCAD becomes blurry and quality of text and lines are hard to see. I tested just plotting to printer and it came out fine. I have also tried to plot using DWG to PDF.pc3 plotter and it also does not come out clean. I have tried to find a solution by reading previous topics but have not found anything similar. Attached is a PDF that shows what is going on. Thanks.
pendean
Message 2 of 6 (419 Views)
Re: Excel OLE qualty when ploted to PDF
01-04-2013 10:59 AM in reply to: theller13
Adobe PDF: is that a third party driver outside of AutoCAD?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Member
Message 3 of 6 (414 Views)
01-04-2013 11:22 AM in reply to: pendean
I'm not to sure it might be I took a screen capture of what I am talking about and attached it.
pendean
Message 4 of 6 (390 Views)
01-05-2013 07:12 AM in reply to: theller13
That's a driver someone added to your setup: autodesk's driver is called DWG TO PDF.PC3
Can you open a 2009 file with an OLE in 2013 and plot it clean? If not, can you share it here?
Member
Message 5 of 6 (344 Views)
01-15-2013 09:26 AM in reply to: pendean
I have not been able to plot any 2009 OLE clean with 2013 attached is a copy of the 2009 version with the OLE and a PDF of what happens when I plot it.
Message 6 of 6 (325 Views)
01-16-2013 07:07 AM in reply to: theller13
I've been working on this for a while and have a fix that works for our business.
Just use a blank excel file with no borders at all, the font is Optimal, the large text is 20pt and the smaller text is 10pt, just use your “table” command & link the excel file (Autocad will add the lines to the file) also if you want to add a lot of text to a cell open note pad, write the text then copy it and past it into the excel area you want it (make sure you "Merge&Center the cells to the full length of your table or additional lines will be shown).
 Let me know what you think. (if you have any other questions, let me know)
Sample = with out large amount of text
Sample 2 = with larg amount of text (pasted from notepad)
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
