AutoCAD 2013/2014/2015
Active Member
Message 1 of 5 (179 Views)
Error while updating AutoCAD
179 Views, 4 Replies
01-14-2013 08:24 AM
While updating one of our AutoCAD 2013 seats I received error Code 1603. What does it mean???error.jpg
*Expert Elite*
pendean
Message 2 of 5 (176 Views)
Re: Error while updating AutoCAD
01-14-2013 08:30 AM in reply to: ktrelski
Did you close AutoCAD first? It appears to be open in your screenshot.
Did you log into WIndows as full administrator? Required.
Did you download the update file locally then try to install it? Or are you trying to install from the web?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
DuncanBrannan82
Message 3 of 5 (170 Views)
01-14-2013 08:47 AM in reply to: ktrelski
My advice would be to download the Service Pack (Presuming it's SP1.1 your installing) to your desktop, right click on the file, go to properties and where it says security, unblock the file.
Might be worth at this stage going to Start and typing in %TEMP% and deleting the files in this location...
Then make sure AutoCAD 2013 is closed, right click on the file and Run As Administrator... If you get any pop ups that say Retry, Cancel or Ignore, use Ignore and it will bypass the issue.
Check on your control panel that SP1.1 has installed by going to Start > Control Panel > Programs > View Installed Updates and hopefully for AutoCAD 2013 it says AutoCAD 2013 - English SP1.1
You may find that if you still cannot do this then do a complete clean uninstall of AutoCAD 2013 (http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617) and try again, alternatively you could always append the Service Pack to your Deployment Image if you have one and install from this...
Hope that helps?
Duncan Brannan
If my post was helpful to you, please could you give "Kudos" and/or mark the "Accept as Solution" button(s) below. Thanks in Advance!
Active Member
Message 4 of 5 (141 Views)
01-15-2013 06:07 PM in reply to: pendean
Thanks. It worked.
DuncanBrannan82
Message 5 of 5 (138 Views)
01-16-2013 05:38 AM in reply to: ktrelski
Glad to help! Could you please leave "Kudos" and "Accept as Solution"
Duncan
Duncan Brannan
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
