When I plot using adobe pdf printer everything goes well, and the pdf document is created, but when I send the document to the plotter (HP desinget 800Ps 42) directly a warning appeares (showed in the screenshot below) and the printing operation is terminated. How to fix this issue??
Sorry, here is a larger shot that shows the message:
I tried this from different machines, with the same printer and the same installed driver and it worked!!!
Hi Mr. Sadallah,
I printed from this machine with different programs to the same printer and it worked, and I checked the driver configuration and it was exactly the same as other machines (including the printer IP) that printed from AutoCAD successfully with this plotter. About PC3 file, I don’t know it and how to check if it is the source of the problem.
There is no PC3 in this plotter name, and in the plot options the hide system printer option is unchecked.
I am using win 8.1, and it worked with other machines (using win 8.1) with the same plotter.
I have the same error with my AutoCAD2015 LT, however it will print from AutoCAD2014 LT...
my PC is on Windows 8.1 pro...
