AutoCAD Forum
Error insalling autocad_architecture_help_2013_english_win_64_32bit?
23 REPLIES 23
Message 1 of 24
acooperator
544 Views, 23 Replies
I have downloaded autocad_architecture_help_2013_english_win_64_32bit and while installing it, I have found this error below.
The real leader is one who helps other people.
23 REPLIES 23
Message 21 of 24
acooperator
@Anonymous wrote:
@acooperator wrote:
Thanks a lot,
IF you really had a look at my post posted in 02-17-2014 04:41, you would have seen that I have replied to Pendean's post with  it says: CRC faild in Help Installer\acad\English\Help Html.zip Unexpected end of archive.
Who exactly are you replying to?  I think that there are people actually trying to help you, but this forum seems to vex you.
 I have replied Pendean's post. This forum doesn't vex me at  all, why would it do? If it does, I will quite quietly leave it.
Message 22 of 24
in reply to: acooperator
I have the same problem with acooperator. Just today I tried to download and install ACA 2013 offline help but failed to install. The download it self is done correctly. But when I tried to run the exe file (self extractor), the application said "Some files are corrupted. Please download again and reinstall". Here below my screen shot
Message 23 of 24
rmaady
I have faced the same problem. I downloaded the file 3 times and every time i get the same error :
CRC failed in HelpInstaller\acad\English\HelpHtml.zip Unexpected end of archive
 the file size of the download is : 118,193 kb, not 188 Mb
The archive file successfully installs in C:\Autodesk\Autocad_Architecture...... , containing setup.exe and some folders, but stops working when it gets to extracting HelpHtml.zip
I downloaded the file from the link below:  On this adress
http://knowledge.autodesk.com/support/autocad-architecture/downloads/caas/downloads/content/download...
http://download.autodesk.com/us/support/files/autocad_architecture_2013_offline_help/autocad_archite...
Anybody have a clue how to fix this ?
can i manually download installation help file from other websites?
Message 24 of 24
rmaady
in reply to: olivier.eckmann
So what? any suggestions?
”Boost
