I have downloaded autocad_architecture_help_2013_english_win_64_32bit and while installing it, I have found this error below.
@Anonymous wrote:
@acooperator wrote:
Thanks a lot,
IF you really had a look at my post posted in 02-17-2014 04:41, you would have seen that I have replied to Pendean's post with it says: CRC faild in Help Installer\acad\English\Help Html.zip Unexpected end of archive.
Who exactly are you replying to? I think that there are people actually trying to help you, but this forum seems to vex you.
I have replied Pendean's post. This forum doesn't vex me at all, why would it do? If it does, I will quite quietly leave it.
I have faced the same problem. I downloaded the file 3 times and every time i get the same error :
CRC failed in HelpInstaller\acad\English\HelpHtml.zip Unexpected end of archive
the file size of the download is : 118,193 kb, not 188 Mb
The archive file successfully installs in C:\Autodesk\Autocad_Architecture...... , containing setup.exe and some folders, but stops working when it gets to extracting HelpHtml.zip
I downloaded the file from the link below: On this adress
Anybody have a clue how to fix this ?
can i manually download installation help file from other websites?
