AutoCAD materials are setup for arch units and I need engineering units. In previous releases I could edit an AutoCAD material and reduce the bitmap size in the dialog shown in the attachement. Did they remove this function or am I just missing it or should I be looking elsewhere?
John Mayo
Solved by Alfred.NESWADBA. Go to Solution.
you can edit the image scaling size, look to that screenshot and let's know if that helped (or not).
HTH, - alfred -
