In the cui under Quick Props or Rollover Tooltips, when I try to invoke the Edit Object Type List it does nothing. Doesn't matter if I select the icon at the top or right-click and select popup menu.
Any one have any ideas?
Kim
Solved by nestly2. Go to Solution.
Try switching to a different AutoCAD profile. If works in other profiles, then I'd say it's probably working but it's "off-screen" (possibly due to switching between single and multiple displays)
HI,
I am experiencing the same problem in Civil 3D 2019.
I have tried switching profiles but it's not helping me.
Never had this problem with 2016-2018. Only 2019 seems to do that.
Please help!
OK, after countless re-tries the Edit Object Type List box suddenly appeared on my screen.
Finally able to sort out my custom tooltips!
