In AutoCAD 2014 I was able to type "ED" (my alias for EDITTEXT), hit enter, and the command would stay active untile I hit enter again. I could fix a mutliline string, or single string, and click outside of the parameters of the text while still being in the EDITTEXT command. In 2015 it exits the command after every string I type in. Is there a default/option I can change to fix this?
Solved by pendean. Go to Solution.
Thanks pendean! I took a LISP writing class last year, so I think I'll try and tackle it. I'll hop back on here if I can't get it.
