Hi, does anybody know why I cannot rotate the 'IP**' attribute in the dynamic block attached, as the attached 'RCD' attribute works fine?
Solved by itbemedg. Go to Solution.
It looks like in your selection of items to rotate that you indeed had picked IP** and the action but you hadn't. Try the one on the right.
