We are starting to install AutoCAD 2014 on our machines. On one of our machines, the user can't get double click editing to work on inserts. I can open the drawing on my machine and it works fine. She is using the same profile and workspace and both machines have SP1 installed. Double click editing works for other objects (MLeaders, Text...) but not for inserts or their attributes. The only way she can edit the attribute text is through the property window.
What am I missing?
Solved by ajohnson. Go to Solution.
(Keeping all of her .CUI somewhere and don't loose them)
then Copy all of your .CUI to her machine, close autocad and restart see if that'll help.
Both are using the same CUI files (on a network).
The double click editing works fine on her AC2013 program, just not the AC2014 version.
I'm going to guess the blocks are dynamic blocks.
In the CUI, the macro for double-click editing a "block" (BLOCKREF) looks like this (from 2010, but probably hasn't changed):
$M=$(if,$(and,$(>,$(getvar,blockeditlock),0)),^C^C_properties,^C^C_bedit)
The macro is the same for dynamic blocks (DYNBLOCKREF).
Notice the (getvar, blockeditlock) part? Compare the value of this variable on the two machines.
Blockeditlock is set to 0 on both machines.
Just noticed that on the offending machines, when you double click on a block, the AutoCAD cursor box (for lack of a better name) changes to the Windows Arrow pointer. You can actually edit the text of the attribute, but you don't get the enhanced editor dialog or the textbox and ruler around the attribute being edited. Also, the only way to get the AutoCAD cursor back is to key the Escape key.
Both dynamic and non-dynamic blocks.
It appears to be the EATTEDIT command. I can't use that command on the offending machines. ATTEDIT works fine on the machines.
It may have been "undefined" (?). Try running it with a dot at the beginning: .EATTEDIT
If it works, try REDEFINE.
There appears to be some change in our setup that modifies the EATTEDIT command for our machines. Double click editing works just fine when using the "<<Unnamed Profile>>" out of the box profile on their machines.
Turns out EATTEDIT is an ARX application (not a "built-in" command that could be undefined).
You could check with APPLOAD to see if it's loading (this is one of those routines that is loaded only if it is run, so check after you attempt to run it). If it's loading, the name AcEattedit should appear in the list.
If it isn't in the list, it may be that the "autoloader" isn't loaded or working.
The "autoloader" is defined in acad2013doc.lsp (usually located in C:\Program Files\Autodesk\<product>\Support\en-us), so that's the next thing you might check.
You could also check to see that the above path is included in your Support Files Search path in Options.
The AcEAttedit.arx appears in the C:\Program Files\Autodesk\AutoCAD 2014 folder on both machines.
It also appears in the APPLOAD Loaded Applications list on both machines.
When we type in EATTEDIT on the machine where the command doesn't work, it prompts with "Select a block:", but then switches to the Windows Arrow cursor and the only way to get back to AutoCAD is to key the Escape key.
Command: EATTEDIT
Select a block:
Assuming you haven't tried this already, I think it may be time (cringe) for the old uninstall/re-install. Make sure Windows is up-to-date, and nothing else is running during the install.
No, it's something in our settings. As I said above, the EATTEDIT works when using the "<<Unnamed Profile>>".
Yes, I see your point.
Assuming one workstation is essentially equivalent to another (in terms of the important Options settings), have you tried exporting an ARG from one of the good machines and importing it on the "offending" one?
VARS2SCR - I didn't know that existed!
We tried it and it didn't fix our problem. Thanks anyway, I'll have to remember that one.
