Document has a command in progress.
in Acad2014, i'have a problem with a file at opening.
I cannot do any command, the file is blocked by this message.
A collegue opened this file with his window's session and had no problem. He saved to another name, but when i try with my session, i'have the same error message.
@steve.denis wrote:Document has a command in progress.
Post your dwg.
here is the file.
i've already try to restart windows, without succeded.
Even when my collegue make a wblock with the entuire drawing, the new file makes the same problem.
@steve.denis wrote:here is the file.
An AUDIT turned up 224 errors. A -PURGE turned up 54 regapps. That would be a good place to start.
I aggree, we tried with my collegue but nothing change.
Completely blocked again in my session.
could you enventually send me the file "corrected" for a another try?
many thanks
@steve.denis wrote:I aggree, we tried with my collegue but nothing change.
many thanks
Here you go.
