AutoCAD Forum
Disappearing Hatch
7 REPLIES 7
Message 1 of 8
FloraSor
1126 Views, 7 Replies
Disappearing Hatch
Hi,can anyone help me with my drawing. Im using autocad 2013. The solid hatch im using cannot be print. The shadeplot options is locked. Ive tried fill, fillmode. Tried to copy it in a new drawing, one day it comes out the next day nothing again and i have to redo again. 😞
7 REPLIES 7
Message 2 of 8
Alfred.NESWADBA
in reply to: FloraSor
welcome @forums.autodesk.com!
The same drawing and same hatch? Or different drawings and/or different hatches.
Are you always use the same printer-/plotter-driver? Have you tried to plot to PDF (just to see what another driver is doing with your graphics)?
A basic option as always is to look if you have installed the current servicepack for your AutoCAD.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Message 3 of 8
hi FloraSor,
you better check the layer you use for the hatch pattern is it printable or not, it might be also on your plot style setting...
hope this will help you..
Virgilio Benedictos
Virgilio Benedictos
AutoCAD 2011 Certified Associate
Please give Kudo if problem solve.
Message 4 of 8
FloraSor
in reply to: Alfred.NESWADBA
Its the same dwg, same file, same plotter.  If i create different new file. Its seems to be ok. But that file, hatch cannot be read. However if use other computers everythings ok. Ill try checking the servicepack.
Thanks for the reply.
Message 5 of 8
FloraSor
already solved my problem, i keep searching and ends up in ribbon panel and gave me idea. My hatches i think are all in the back order. So i tried using the hatch in front and got it properly fix in printing.
Thanks guys.
Message 6 of 8
Alfred.NESWADBA
Thank you for your feedback!
- alfred -
Alfred NESWADBA
Message 7 of 8
HI
THANKS FOR YOUR FEEDBACK,,,
CAN YOU GIVE US KUDO? HEHEHEHHE...
Virgilio Benedictos
Message 8 of 8
done 😉
Alfred NESWADBA
”Boost
