Hello All,
I am trying to draw dimensions only a very annoying line keeps showing up for my angles. I want the line in between what I am measuring to disappear and leave only the arrows on the outside and the degrees. I have spent a lot of time trying to figure out how to get it to disappear with no luck. Any suggstions. Any help is very much appreciated!!
I have attached an image with what I would like to get rid of
Thanks!
Solved by Kent1Cooper. Go to Solution.
Solved by jggerth1. Go to Solution.
Thanks for the help, but arrow size isn't helping me. See attached. Am i missing somthing?
DIMTOFL
= DIMension: Text Outside? Force Line [inside]
Turn it off, presumably in the Dimension Style definition, but you can also impose it on individual Dimension entities with DIMOVERRIDE or in their Properties.
