I'm not new to AutoCad but have a question?
What is the difference between STARTUP (System Variable) Values 2 and three ... I'm confused .. is there an example to apply?
.. Thanks very much
Solved by Alfred.NESWADBA. Go to Solution.
I tested it too many Times .. change from startup system variable value 3 to 2 and vise versa ... but noticed no difference happened !!
so my new question is when i should set startup system variable value to 2 and when set to 3 ?
In both settings you land in the New Tab ribbon, the difference is when you click onto the "Start Drawing" field:
with setting 3 ... the default template is used for the new drawing
with setting 2 ... clicking "Start Drawing" brings you to a dialog where you can select the layout to use.
HTH, - alfred -
Thanks a Lot
You gave me the key to solve the mystery
The Red Words was the key ... I found I had no default template, so, after adding a default template from (Options-Files-Template Settings-Default Template File Name For QNEW), it put things right ...
thanks again ...
