I was just explaining to a client about the search bar for commands in AutoCAD under the Application Menu and it crashed on me when I typed in LINE and let it set for a second. A couple of my coworkers are experiencing the same. I wonder if its just us or???
Do you CRASH when doing the same thing?
Solved by Volker_C. Go to Solution.
I'm not experiencing this behavior. Typing in "Line" and letting it sit for a few seconds does nothing, other than continue to display the search results. Running regular AutoCAD 2014.
We've seen a few issues with AutoCAD crashing when typing a command in the Application Browser Search field. A fix is being worked on.
The way to resolve this at this time is to reset AutoCAD to default settings. If you are using Windows 7 I would also recommend disabling the User Account Control, which you can re-enable after the reset. The following are instructions for both procedures.
Set the UAC (User Account Control) to "Never Notify"
You can do this using the following steps:
In the Windows Start Menu Search field, type UAC, Press Enter.
In the User Account Control Settings dialog, change the Slider Control to "Never Notify".
You will need to reboot the workstation.
Reset AutoCAD to default settings
How to resolve fatal errors by restoring default settings
Hope this is helpful, Volker
Please let us know if your questions have been answered by selecting, "Accept as Solution"
Volker C.
SR Technical Support Specialist, KDE
Autodesk Customer Council | Only One AutoCAD | AutoCAD Blog
