Hello everyone.
Can anybody tell me how to change the default behaviour when I draw an arc?
I want to write "arc" in the command line, and start drawing it by its center first, then its start point, and I finally the end one. I don't want the default 3 points method.
I do this faster drawing circles and trimming them, than selecting the suboptions of the arc (center, start, etc.). It should not be XD
Thanks!!
Solved by Patchy. Go to Solution.
Solved by Alfred.NESWADBA. Go to Solution.
welcome @forums.autodesk.com !
There is no sysvar that can be set for that, but you might use that lisp statement to define a command MYARC that works like you want:
(defun C:MYARC() (command "_ARC" "_C"))
If you edit your ACAD.LSP and write add the above line of code to the existing content then the command MYARC will exist everytime you start AutoCAD.
HTH, - alfred -
May I add that acad.lsp has to be in a path that autocad can find it and the box in OPTIONS, System tab has to be checked for acad.lsp to be loaded with every drawing.
and ACADDOC.LSP can do the same thing.
