AutoCAD 2013/2014/2015
Member
Message 1 of 5 (188 Views)
[DXF] Application defined codes in entities
188 Views, 4 Replies
02-14-2013 12:27 AM
I'm looking for a way to tag entities (for example arc) in a DXF with an numeric ID of my choosing. I've been trying to understand the DXF reference and find examples of how to do it, but there is not much information available. My interpretation of the standard is that I'm allowed to do this:
0
ARC
8
Layer1
10
-1.734315
20
-1.975000
40
0.300000
50
225.000027
51
270.000065
102
{MYAPPLICATION
2000
13
102
Where 2000 is my application defined code and 13 is my numeric ID value.
Is this correct use of application defined codes?
EDIT: I also asked a similar question at stackoverflow, without anyone being able to answer it.
*Expert Elite*
Alfred.NESWADBA
Message 2 of 5 (181 Views)
Re: [DXF] Application defined codes in entities
02-14-2013 12:38 AM in reply to: dagur_
look to Extended-Entity-Data (EED) in the DXF-documentation (>>>details<<<), there you can assign some additional values to each element.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
Member
Message 3 of 5 (168 Views)
02-14-2013 12:54 AM in reply to: Alfred.NESWADBA
Like this?
0
ARC
8
Layer1
10
-1.734315
20
-1.975000
40
0.300000
50
225.000027
51
270.000065
1001
MYAPPLICATION
1070
13
Am I using xdata correctly? Also, is this correct/better way to define my numeric ID?
*Expert Elite*
Alfred.NESWADBA
Message 4 of 5 (150 Views)
02-14-2013 01:21 AM in reply to: dagur_
the easiest way to verify how EED's should be stored is to create a new drawing, then draw a new line, start command _XDATA (from the express tools) and add test data to this line.
Afterwards save the file as DXF and look to the EED how it's stored.
Good luck, - alfred -
Alfred NESWADBA
Member
Message 5 of 5 (130 Views)
02-14-2013 06:51 AM in reply to: Alfred.NESWADBA
Thank you, this solves my problem. Using _XDATA as suggested, Autocad added the following to my arc description:
1001
MYAPPLICATION
1002
1070
    12
1002
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
