AutoCAD Forum
Cut Paste not landing on SNAP
8 REPLIES 8
Message 1 of 9
Scottu2
1581 Views, 8 Replies
I have a problem when I paste a block, that it is off the snap value by a small like 0.000099939.
I know that Cut with Base Point will work, but why not the following:
Did messup my original drawing template?
Thanks.
Test Setup:
set the dimention precision to 8 places, DIMDEC 8.
set the SNAP On with the value 0.0625 (any)
draw a box 3 x 8 (lines or pline)
draw X & Y dimensions from one of the box's corners to someware in space
Notice the nice numbers are to the snap value.
Cut (ctrl-c) the box and Paste (ctrl-v) it someware in space.
draw x & y dimensions from one of the box's corners to someware in space
Notice the values are Not exactly on snap.
End.
8 REPLIES 8
Message 2 of 9
sthompson1021
in reply to: Scottu2
Hi, try typing in UNITS and see what your precision is set to for lenght. change it to 8 places and see if it makes a differance.
Message 3 of 9
Scottu2
in reply to: sthompson1021
UNITS precision length is set to 8 places.
Message 4 of 9
GrantsPirate
You need to use COPYBASE and snap to a corner for a base point.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 5 of 9
sthompson1021
Not sure why it does it but for some reason pasting off the clipboard does not honor the snap setting. If I just copy the box, the dim will have the right value but not doing a ctrl v.
Message 6 of 9
Scottu2
The UNITS does not show the small value change. Its only when i modify the DIMStyle units precision to 8 places and measure or dimension the lines to the empty work area. I was expecting the objects to land on the snap setting increments. It appears on screen, but its actually off by a little.
Message 7 of 9
jggerth1
you're not using the clipboard to cut and paste in the same drawing are you?
Message 8 of 9
Scottu2
in reply to: jggerth1
I use the keyboard ctrl-c ctrl-x ctrl-v, the classic toolbar icons and Ribbon and get the same offset when pasting. Even within the same drawing or into another drawing.
Message 9 of 9
Scottu2
I was hoping to avoid the extra mouse clicks and realigning with the snap.
The standard cut/copy and paste is just not reliable.
I will just use the cut/copy with BASEPOINT CTRL-SHIFT-C from now on.
Thanks guys for your replies.
”Boost
