AutoCAD Forum
Cut Hole in 3D Model
6 REPLIES 6
37670 Views, 6 Replies
Hello:
   I'm very new to AutoCAD. I am working with a cylindrical shape (solid) and I have revolved it around an axis, but I need to "cut" two holes through the part. How can I achieve this? Any suggestions would be greatly appreciated. Thanks
Ryan
6 REPLIES 6
maxim_k
Although I don't understand what is "revolved cylindrical shape (solid)", assuming that the resulting geometry is 3D Solid, you can create cylinders with diameter equal to diameter of holes you want to cut, and then subtract these cylinders from  "revolved cylindrical shape (solid)" with SUBTRACT command.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
in reply to: maxim_k
I have attached a drawing with an example of what I'm trying to accomplish. I would like to cut two (2) holes, one inch (1") in diameter, exactly 180 degrees apart from eachother that will "remove" the material where the hole is cut.
I tried using the subtract command but could not get it to work. Any suggestions or ideas are welcome!
File wouldn't attach, had to zip it. Please let me know if anyone has any ideas! Thanks
Patchy
Make a REGION out of the cross section, REVOLVE it, then draw a circle, Presspull or extrude thru the cylinder then subtract.
mrkaplan
in reply to: Patchy
your original model is not solid . its usually best to work with solids in 3d , as patchy did . then you can either edit them or add / substract other solid volumes .
usually you get a non solid volume when the shape (polyline) you use for revolve or extrude is not closed .
in reply to: mrkaplan
This info was very useful to me as well.  But I would like to ask, what if the hole is at, lets say 5º angles ( a slight V shape)?  Just build the object and merge it then subtract?  Seems like it would be the same, I didnt know if the angles come into play or not.
”Boost
