I am trying to create a custom style for my company, so when we all work on a project all the settingswill be the same no matter who is working on it. Is there a fast and efficient way to create a custom style for all the autocad users at my work?
I know I can create a template and have everyone work off of that but I would rather have the start up settings pre set to my standards automatically.
The setting I am trying to set are:
We are all using autocad civil 3d 2013
I think the template file would be the simplest way to go by far. If you don't use the default AutoCAD templates, you can delete them so that yours is the only one that shows up for your users. You can also have AutoCAD point to your custom template so it is the default when creating new drawings. If you store the template on the network and have all the users point to that file, you can update the file for all users simultaneously.
In what situation do you see the LISP method having an advantage over using a template file? I'm not saying the LISP method isn't the best for you, but it'd be good to make sure there's not a less complicated method that will help you first.
In vanilla AutoCAD, the term "style" has a slightly different meaning than in Civil3D. If this is about Civil3D styles, I would recommend you ask in the Civil3D board: http://forums.autodesk.com/t5/AutoCAD-Civil-3D/ct-p/66
