AutoCAD 2013/2014/2015
Message 1 of 46 (21,230 Views)
Cursor disappears only on drawing window
21230 Views, 45 Replies
05-03-2012 10:22 AM
All of a sudden my cursor will become invisible. This happens only with AutoCAD. and if I switch between drawing windows it will appear on another drawing file. I have to close the drawing and open it again and then the cursor will be back only to disappear again. The cursor is visible if I move it back to the ribbon or bottom controls. It seems to happen only when it becomes the cross-hair cursor. I can still make selection windows and right click.
Mouse is working fine with all other programs and drivers are up-to-date
What gives?
Signed,
Perplexed
Distinguished Contributor
greg.battin
Message 2 of 46 (21,208 Views)
Re: Cursor disappears only on drawing window
05-05-2012 08:59 AM in reply to: Jlasante
I am getting the same behavior consistanly upon exiting the block editor. I'm getting tired of exiting the drawing and re opening it just because I exit the block editor...
Member
tgtreadway
Message 3 of 46 (21,179 Views)
05-07-2012 08:25 AM in reply to: Jlasante
Snap Spacing?
Message 4 of 46 (21,146 Views)
05-08-2012 08:15 AM in reply to: Jlasante
This was also a problem in 2012. It appears to happen when you change from model space to paper space at exactly the same time that autosave kicks in.
Autodesk obviously don't think this is a problem that requires fixing.
Sometimes; if you click back into model space and regen all, the cross hairs will reappear, but not every time.
Cheers
Alan
Message 5 of 46 (20,905 Views)
06-07-2012 12:00 PM in reply to: Jlasante
I never had a problem with this when I had MEP 2012 running on a machine with Windows XP.  I have a new machine running Windows 7 with MEP 2012 and have this problem all the time when switching from model space to paper space.
Searching everywhere, the only workaround I found is changing the visual style from 2d wireframe to something else, then back to 2d wireframe.
And yes.....I updated everthing.
Help Autodesk!
Message 6 of 46 (20,066 Views)
09-07-2012 12:32 AM in reply to: Jlasante
I just set the profile current - (Tools>Option - Profile Tab and click 'Set Current') - refreshes the current profile and bring that **** cursor back to life.
Active Member
Kid2Lt
Message 7 of 46 (19,106 Views)
11-01-2012 09:26 AM in reply to: petervose
This sounds like the answer.  Im exited; thank you.  Tools, Options, Profile Tab, Set Current.  Im trying it right now.
Active Member
Kid2Lt
Message 8 of 46 (19,084 Views)
11-01-2012 01:27 PM in reply to: petervose
Nope, this did not work.  This is not the solution.
Member
Message 9 of 46 (18,820 Views)
11-12-2012 12:58 PM in reply to: dvclark5
Worked. Thanks
Message 10 of 46 (18,800 Views)
11-13-2012 01:57 AM in reply to: moshe
Autodesk still don't think this problem is worth fixing then???????
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
