AutoCAD Forum
Crosshairs
8 REPLIES 8
Message 1 of 9
chreese22
804 Views, 8 Replies
Crosshairs
Does anyone know how to get my crosshairs straight up and down after looking at this screenshot? I have tried the snapang command and set to zero, but it lines the crosshairs up with the ucs.
8 REPLIES 8
Message 2 of 9
kentr8
in reply to: chreese22
change ucs to world
Message 3 of 9
chreese22
in reply to: kentr8
It is set to world. I also have Carlson Survey software made by autodesk on my computer and it has a command called "resetxhairs" which works, but snapang doesn't seem to.
Message 4 of 9
sthompson1021
Hi, try setting the UCS to VIEW
Message 5 of 9
chreese22
in reply to: sthompson1021
That did it, thanks so much.
Message 6 of 9
kentr8
how about object, draw a straight line the way you want to see the cross hairs first then pick it as your object
Message 7 of 9
PatrickHughes
I'm not sure you really want to do that. Changing the UCS can have some unexpected consequences.
Patrick Hughes
Engineered Design Solutions
Developer of CadTempo - Cad Time Tracking
www.cadtempo.com
Message 8 of 9
chreese22
in reply to: PatrickHughes
Now it is saying "Viewport is view-locked. Switching to Paper space. Switching back to Model space."
Does this have something to do with typing is "UCS" then typing "view"?
Message 9 of 9
jggerth1
no, it simply means that at some point you locked the viewport.  Ususally a good thing, so that zooming around will not trash your plottable sheet and leave an unexpected display in the viewport.
”Boost
