AutoCAD Forum
Correcting improperly defined attributes
5 REPLIES 5
Neilw_05
275 Views, 5 Replies
I recevied a drawing from a consultant. I dumbed it down to ACAD 2004 using DWG true convert to make it compatible with Land Desktop 2004. Not sure what version the originals are but I have ACAD 2013 if it can help with my problem.
The problem is it has call out leaders that consist of polyline outlines and the text is a stand alone block attribute. In other words the attributes are not included in any block. When I look at the properties of these attributes I find that the text value of the call out has been assigned to the tag name, not the attribute value. Thus each call out is an attribute with a unique tag name. I need to mask these call outs using the TEXT MASK express tool. The tool will not work on these attributes so I need to find a way to convert them to text. The explode command does not work on them. I also have Dotsoft ToolPac but it isn't able to convert them either, probably because it was not designed to handle attributes that have been defined this way.
I could really use some help to get this resolved by the end of the day (about 3 more hours).
I've attached a sample if anyone is willing to take this on.
TIA
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
5 REPLIES 5
steve216586
in reply to: Neilw_05
Why use text mask? Select similar then place on different layer and freeze.
"No one can make you feel inferior without your consent. "-Eleanor Roosevelt
abubakars
There is a lisp file which will convert the Attribute Definiton to Text, search the forum for the lisp file "AttDef2Text.lsp"
hope this will help
Neilw_05
in reply to: steve216586
I need to show these text values, not hide them. I need to mask the background.
WIN 10 64 PRO
Neilw_05
in reply to: abubakars
I found the tool and surprisingly it works in spite of the unorthodox attributes.
Thanks!
WIN 10 64 PRO
abubakars
Glad to help and credits goes to the original author who created this lisp routine.
”Boost
