AutoCAD 2013/2014/2015
Message 1 of 24 (10,342 Views)
Copy Paste from another drawing does not work
10342 Views, 23 Replies
01-13-2013 11:53 AM
When I use copy or copy with base point and paste or paste to original coordinates in another drawing, nothing is being copied.
I use autocad 2013
The isuue is dwg related. It only happens when i paste to some of my dwg (usualy the most important ones...).
All the drawing files that are affected are in 2013 format, but if i save them to older version the problem persist.
Please help!!!
I ve tried
purge r, purge a, audit, save
wblock explode, purge a, audit, save
to no awail.
Tried many other solutions sa well, but nothing worked.
What on earth could be wrong with DWG to prevent pasting from another drawing?!
PS: Those drawings have been saved to lower formats before.
*Expert Elite*
Alfred.NESWADBA
Message 2 of 24 (10,334 Views)
Re: Copy Paste from another drawing does not work
01-13-2013 12:26 PM in reply to: ivor.bach
There are so many reasons why that could fail like
  • do a ZOOM EXTENTS after pasting
  • verify if layers are frozen/switched off in the destination drawing
  • blocks copied that (with same name) already were defined in the destination drawing (and may have same name, but other definition)
At least you can _WBLOCK the content you want to get into the other drawing to create a temporay DWG with the copy-content ... and then insert this drawing into the destination drawing.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
Valued Mentor
Message 3 of 24 (10,331 Views)
01-13-2013 12:35 PM in reply to: ivor.bach
as a workaround , you could use wblock the items you need to copy and paste .
you could wblock them to a local folder specified in your options paths.
  default name will be "new block", accept that
then you can use a lisp to  insert "new block"  to another drawing .
i e :
(defun c:insertnewblock (/p1)
(setq p1 (getpoint "\nPick insert point :"))
(command "_-insert" "new block" p1 "" "" "" )
(commmand  "_explode" "_L" "")
(command "_-purge" "_bl"  "new block" "_n")
 (princ)
make a pgp alias for this lisp ,  this can be as quick as copy paste
Message 4 of 24 (10,320 Views)
01-13-2013 04:04 PM in reply to: mrkaplan
INSERT does not work, Insert as reference does not work...
If i wblock my current file, in the wblocke file i have same error...
nothing helps.
*Expert Elite*
cbenner
Message 5 of 24 (10,298 Views)
01-14-2013 04:43 AM in reply to: ivor.bach
Can you post one of the affected files here for us to look at?  Something is not right.
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cbennertipstricks.blogspot.com/
*Expert Elite*
pendean
Message 6 of 24 (10,294 Views)
01-14-2013 05:39 AM in reply to: ivor.bach
First you need to confirm the COPYCLIP took place: the problem may be the source file, not just the destination file.
Second, it appears you did not try -EXPORTTOAUTOCAD command, a great tool at removing AEC content that may be the culprit (assuming neither you or the file creators/recipients need them): aim for a 2007 format DWG file.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
DuncanBrannan82
Message 7 of 24 (10,281 Views)
01-14-2013 08:50 AM in reply to: ivor.bach
Have you tried the AutoCAD System Variable "PICKFIRST" and set it to 1 rather than 0 when you are copying...
Hope that helps?
Duncan
Duncan Brannan
If my post was helpful to you, please could you give "Kudos" and/or mark the "Accept as Solution" button(s) below. Thanks in Advance!
Message 8 of 24 (10,248 Views)
01-15-2013 08:13 AM in reply to: DuncanBrannan82
it was set to PICKFIRST=1 all the time...
EXPORTTOAUTOCAD was done, as well as SPURGE, nothing helped.
Message 9 of 24 (10,247 Views)
01-15-2013 08:19 AM in reply to: cbenner
dear cbenner file ill post the file tommorow.
DuncanBrannan82
Message 10 of 24 (10,212 Views)
01-16-2013 05:36 AM in reply to: ivor.bach
Not sure if anything has happened to this post but i got a reply stating...
"I've deleted everithing visible from my file, but the problem persists. There are a bunch of blocks that cannot be purged."
"The file is attached."
But i cant seem to find it???
Duncan Brannan
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
