Hello, I am currently using Autodesk 2013 (Student Version). I have a pretty large .dwg file that I am looking to convert to .stl or .iges for 3D printing. I have attached the zip of the file. If anyone could help, it would be much appreciated.
Solved by Alfred.NESWADBA. Go to Solution.
What 3D printer do you have?
Is your printer capable of printing to very thin resolution?
Your cylindrical features are very small for printing - I'll wager that your printer is not going to produce the results that you expect.
We're going to 3D Print at a company using a PolyJet HD, with a layer thickness of 16 microns and a minimum feature size of around 304microns. The cylindrical features are small but based upon the specifications they should be able to be printed by this precise 3D printer. I just need to provide a .iges, .stl, step, or x_t form of the file.
So you are going to end up with cylinders the diameter and height about the same as the thickness of 3 sheets of paper (and very close together).
Is that really what you want?
Yes, that is correct. We are looking at this as a fast way to produce a large track of micro-mm scale (tiny) pillars. We are studying the fluid flow through these pillars, so we do indeed want them to be that small.
your cylinders are part of an array object, imho that can't be exported to STL, you have first to explode that array object, then union all together, then you can export the resultind 3D-solid as STL (it used some time to get the mass of cylinders unified, but it worked).
The resulting STL has 350MB, so I can't upload it here. But you can do the same steps and will get it working.
Good luck, - alfred -
@Anonymous wrote:So you are going to end up with cylinders the diameter and height about the same as the thickness of 3 sheets of paper (and very close together).
I love it when people ask for help with a particular operation, and then "the helpers" critique their (in this case) dwg. Twice, this time. What happened to just answering their questions? This place has too many experts for its own good.
