AutoCAD 2013/2014/2015
Active Member
MiDu75
Message 1 of 7 (566 Views)
Convert ribbon menue items into classic workspace.
566 Views, 6 Replies
11-13-2012 01:49 AM
hi there...
i having a fully working ribbon in ACAD2013. it is a registered dll that is originally coded in vb.net.
unfortunatley the functionality is only visible at the drafting & annotation workspace but is desperatly needed in classic workspace mode.
for hours i am trying to find a way to make my functionality working in classic workspace too.
is it possible to extend the classic workspace in acad2013 with my functions? if so, how, or where can i get more detailed information to solve my task.
thank you.
*Expert Elite*
pendean
Message 2 of 7 (561 Views)
Re: Convert ribbon menue items into classic workspace.
11-13-2012 04:38 AM in reply to: MiDu75
Which functions exactly? Elaborate please, your post is light on specifics.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Active Member
MiDu75
Message 3 of 7 (557 Views)
11-13-2012 04:49 AM in reply to: MiDu75
...re
i already have methods implemented within my ribbontab that works as expected.
a customer is using my ribbon but wants the functionality also in the Classic Workspace which means i need to extend the toolbar in the classic Workspace with another menue-item that contains menue-sub-items that trigger the same methods like those in my ribbon.
*Expert Elite*
pendean
Message 4 of 7 (554 Views)
11-13-2012 04:59 AM in reply to: MiDu75
CUI command, drag and drop to toolbars or screen menus into a classic workspace's toolbars and screen menus: toolbars can call sub-toolbars (you must create these as standalone toolbars first) and appear as expanded buttons, and you can turn on and off toolbars with your macro/lisp/customzations if needed.
Same with pulldown menus.
Dive in, start exploring CUI in depth.
Active Member
MiDu75
Message 5 of 7 (519 Views)
11-15-2012 02:52 AM in reply to: pendean
thank you for your reply.
i have followed your instruction as i understood them.
unfortunatley, although my ribbontab is visible in drafts&annotaions workspace, it is not visible anywhere within the  cui command window.
for my ribbon i dont use any .cui or .cuix file. it is a .net-dll that is just registered and initialized on startup.
i also like to put my ribbon-items in the classic workspace in the menuebar.
i may find out myself how to do that but i am looking for some kind of tutorials; there are many out there for the ribbon, but i cant find any clues to select the workspace in which i want to put my commands to.
*Expert Elite*
pendean
Message 6 of 7 (512 Views)
11-15-2012 05:50 AM in reply to: MiDu75
You might need to repost and find more specific help in the .NET Customization Forum:
http://forums.autodesk.com/t5/NET/bd-p/152
But remember: RIBBON is new and designed to do more, CLASSIC is from the 1980s before you ever thought of MSWindows, let alone .NET
*Expert Elite*
dgorsman
Message 7 of 7 (499 Views)
11-15-2012 11:50 AM in reply to: MiDu75
If you programmatically create Ribbon elements, then chances are you would have to create toolbars the same way.  But I strongly encourage you to create a dedicated CUIx for your product that can be partially loaded.  I have dealt with such programmatically generated UI content before and from a CAD Admin standpoint they are a royal PITA to manage.
If you are going to fly by the seat of your pants, expect friction burns.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
