I have a drawing from a contractor that is dimensioned in metric units. I have been tasked with converting the displayed units to inches for our machine shop. I have tried to display alternate units but they don't appear, yes, I did check the "display alternate units" box. I am using AutoCAD 2013.
Thanks for your help,
Joe
Welcome to the Autodesk forums.
Perhaps the dimension text has been manually overriden? If this is the case, it could make your job really easy by just removing the override, or it could indicate the drawing is not dimensionally correct and they used manual overides to to "fix" the problem with the model.
Attach the drawing if you need more assistance.
Ok so used "DIMSTYLE". clicked MODIFY, Alt Units tab, I checked "display alt. units", changed unit format to architectural, precision to 0'-1/8", muliplier for alt units set at .0393701.
I've also tried to use -dwgunits, selected 1. Inches, 4. Architectural. 3. 1/8" Precision, Yes, Scale inserted objects, Yes, match INSUNITS to drawing units, Yes, scale objects in current drawing to reflect change.
Also I'm pretty sure it would be illiegal for me to attach the drawing otherwise I would have in my original post.
If it's the right dimstyle, you don't have to do a thing.
Try this:
Click on your dimension, right click and choose SELECT SIMILAR, go to PROPERTIES and turn the ALT Enabled to ON.
Ok so I clicked the Dimension and then "select similiar", then the power dimensioning ribbon appears above and from there I dropped down the Dim Text menu and changed my primary units to Architectural. That changed all the dimensions so thank you for that.
I have to do this to a few more drawings so I tested this method on another drawing and when I change the primary units some of the dimensions didn't change, including the one I originally selected before "select similar." Do you have any suggestions for that?
I don't use Mechanical to know Power Dimensioning.
I think if a dimension has been overriden in someway, you need to turn it back to a dimstyle that is available before you can do anything again.
Most of my dimensions are now in inches. Some of them are still displayed in millimeters after I updated them. Do you know why those dimensions did not update with the others?
It does not. The dimensions that stayed in metric form were underlined (not sure if that is significant) and when I MATCHPROP them the underline goes away but the value remains the same.
If there is a text override, the Properties panel will display it at the bottom of the "Text" section.
Also, DIMREASSOC will reset the dimension text to it's actual value as defined by the Dimstyle
@Anonymous wrote:
I don't see the Alternate Units tab in PROPERTIES to try that option.
In the DIMSTYLE dialog >Select style to change > MODIFY button > ALT UNITS tab
DJ
