In AutoCAD 2015 the command line obscures the "reload xref note". How do i put the command line back down to where it was in AutoCAD 2012?
It does not for me in 2015 with a docked command line
Here is mine:
If your command line is floating, move it/resize it so that it does not overlap the tray notification
you could dock the command line, or you could turn it off. i found that it is unecessary to have the space used up by something telling me what command i have live. you can use dynamic input as your command line and use F2 to pull up the text window if you need to read past commands or distance etc.
