Oops! Sorry All for the double posts. I didn't think the first post went through!!!
version?
It's not something I've experienced, in 2014 or 2015. As long as the circle is either within or touched by the cossing selection window, it's selected.
Try using the CP option optiion, and pick the four points that the crossing window would use. what happens?
The image shown is in 2015 and is crossing all the circles, but does not select them as the same procedure in 2014 would select all the circles.
Thank you for you response!
i have been encountering the same issue as described by JeffLMoran. (Autocad 2015)
Hi @thebearjed,
The oldest version I have installed is 2016 but if you can share that file I would like to see if that is an issue still in this version.
For what it's worth, I don't remember if there was a solution for the issue, but I believe it was only an issue in 2015. I am current using 2018 and it's not an issue.
Does the selection not work or just the SELECTIONPREVIEW (because it's set to 0 instead of default 3)?
- alfred -
