I am trying to determine if there is a way to change the selection feature which highlights the entire selection back to the way it displays selections in 2014 and earlier versions. The selected objects were simply shown as dashed-faded lines instead of having an outer glow applied to the entire selection.
Is it still called SELECTIONPREVIEW in 2014? I don't have 2014 yet. I remember someone on the forums mentioning another variable but it escapes me for the moment.
DJ
I'm talking about the feature where when you select an object, the object is highlighted instead of dashed. I figured it out: Selectioneffect = 0 is dashed, selectioneffect = 1 is highlighted.
