Hey,
So I have received a few (15) drawings from an architect and I am compiling them in an overall xref so we can then work around it. Each drawing has several blocks all with color set bylayer, but within the blocks a lot of the lines are set by different colors.
What I am trying to do is change all the magenta colored lines to number 8, without changing the rest. So far I had to go into each block, select all the magenta lines using filter, and then changing them to number 8.
I am aware of commands such as setbylayer, but in this case they would not work as the layer color is green and the rest of the linework is fine.
Changing plot settings, although very quick, is not an option. We have global setting that we use throughout the office and would create a bunch of other problems.
I know I am kind of reaching here a bit, but does anyone have any thoughts or knows of any lisps that might make this tedious job a little bit faster.
Cheers
Solved by 3wood. Go to Solution.
You can try attached CHZ20.vlx which can change entity color including block subentity color (need a free registration) based on a selected color matching file.
When it prompts for the color matching file, you can use attached example txt file which sets up a rule to change all color 6 (Magenta) to color 8. You can also modify it or add more rules as you need.
Settings as below:
Are the blocks redundant? Do they occur often in other drawings or are they specific for only one drawing?
Thanks steve216586,but unfortunately they are different. I thought about changing them in one and replacing them in the others, but the drawings are very badly conceived.
It's a long 3-day weekend in the UK, so I won't be back to work until Tuesday when I wanna try 3wood's program.
Hey 3wood,
Thanks a lot. It did exactly what I needed. There was a problem with replacing 6 to 8, but when I changed the txt file to 6 to 1, it changed everything!! I am guessing that it might not read 8 as a true color or that it might need to be added with its true value.
Cheers
Eliza
