AutoCAD 2013/2014/2015
Active Member
karla_jones
Message 1 of 13 (1,168 Views)
Cannot import dwg files into AutoCad 2013
1168 Views, 12 Replies
12-09-2012 10:14 AM
I just downloaded AutoCad Architecture 2013 and I am having trouble importing DWG files. When I select the file nothing happens. I had AutoCad 2012 for Mac and it worked fine. I switched to 2013 for PC via Parallels on my iMac because I was told that the PC version was better than Mac.
Please help!
Karla
*Expert Elite*
Alfred.NESWADBA
Message 2 of 13 (1,161 Views)
Re: Cannot import dwg files into AutoCad 2013
12-09-2012 10:21 AM in reply to: karla_jones
What command do you use?
Have you tried different source-drawings (drawings to be imported) and also different destination drawings (drawings where you want to place them).
When you look to the command-line, what does it tell you during the command-execution?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
Active Member
karla_jones
Message 3 of 13 (1,157 Views)
12-09-2012 10:26 AM in reply to: Alfred.NESWADBA
No, I am trying to import dwg furniture files. The command I use is _IMPORT or I select the Import icon. The files appear, then I click open. Nothing happens and I do not see anything in the command line. It's almos as if I didnt select anything.
Active Member
karla_jones
Message 4 of 13 (1,157 Views)
12-09-2012 10:27 AM in reply to: Alfred.NESWADBA
I mean to add that I am still new at AutoCad so I might be missing something :smileyindifferent:
Thanks!
*Expert Elite*
Alfred.NESWADBA
Message 5 of 13 (1,153 Views)
12-09-2012 10:32 AM in reply to: karla_jones
When I use command _IMPORT I can't select any DWG-files! Look to the list of filetypes I can select during command _IMPORT. Make a screenshot from your dialog and file-options (just to make sure for me that ACA does not work differnent to plain AutoCAD with this command).
- alfred -
Alfred NESWADBA
Active Member
karla_jones
Message 6 of 13 (1,145 Views)
12-09-2012 10:53 AM in reply to: Alfred.NESWADBA
The DWG files appear as if I can select and import them. Here is a screenshot of what I see. The objects you see in the drawing were already there before I opened this file in the 2013 version.
*Expert Elite*
Alfred.NESWADBA
Message 7 of 13 (1,135 Views)
12-09-2012 11:03 AM in reply to: karla_jones
am I right that this is not the _IMPORT command, but instead it is the _INSERT command? If you really tried _IMPORT then I would undertand it's not working, in that case how does _INSERT work?
Also when you selected one DWG-file and clicked onto button "OPEN" ==> what does your commandline show up? Press <F2> to get the long version of the text-window and let us know, what's in there.
- alfred -
Alfred NESWADBA
Active Member
karla_jones
Message 8 of 13 (1,133 Views)
12-09-2012 11:17 AM in reply to: Alfred.NESWADBA
When I select INSERT-->OPEN--> I get an invalid response in the command line. (see screenshot 1) I tried inserting objects already in the dropdown menu sucha s "chair" but it appears extremely large (see screenshots  2 & 3)
Active Member
karla_jones
Message 9 of 13 (1,131 Views)
12-09-2012 11:18 AM in reply to: karla_jones
Also note, this CAD drawing was existing. I am workin on this for a class project. Everything in it was done with the exception of the coffee bar and chairs.
Thanks!
*Expert Elite*
Alfred.NESWADBA
Message 10 of 13 (1,128 Views)
12-09-2012 11:23 AM in reply to: karla_jones
You didn't finish the insert as AutoCAD is asking you to show the insertion point (in your screenshot 3/command-line)
- alfred -
Alfred NESWADBA
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
